FS: GM Stage 3 PCM / 06-07 Cobalts
Old 09-01-2008, 10:37 PM
sput's Avatar
sput is offline
Old 09-01-2008, 11:00 PM
hungryhip-ccp's Avatar
dude make a new thread... with everything i said in post #25
hungryhip-ccp is offline
Old 09-01-2008, 11:06 PM
scampbell's Avatar
Originally Posted by hungryhip-ccp
hmm people are broke right now... if i were you i would make a thread about how you can go stage three and avoid the dealer and voiding warentee by just buying 42's this ecm and whatever pulley they wanna run for like 500 total...
nates 2.9 $50
ecm $300
42's $150
you will get a bite for sure then...
killer deal and the dealership knows nothing...
so what would be the benefits of runnin this pcm with my current setup? mods are in my sig...
scampbell is offline
Old 09-01-2008, 11:10 PM
well here is 1 benifit that would give you approx 20 more hp...
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/more-reassurance-meth-maintains-100-octane-mode-stage-3-a-129820/
and adjustable rev limit...
Old 09-01-2008, 11:30 PM
scampbell's Avatar
so basically just one wired switch can bypass the a/c being turned off thats pretty interesting i am pretty sure i could handle that...and the interceptors can do a case relearn right or is that required for the s3 pcm? so basically if i was gonna do a wot run i could just flip the input switch for 100 octane mode and the 50/50 meth solution would hold the octane above 100 until the end of the run and then just turn the 100 octane mode off?? sorry for all the questions.
Old 09-01-2008, 11:42 PM
yes, exactly
Old 09-02-2008, 01:19 AM
rukkee's Avatar
So if i already have a stage 3 pulley , this and a dualpass end plate would be the whole kit right? I wonder if i could get away without the dual pass in the colder weather this fall? I just don't want to tear the car apart to change it right now.
rukkee is offline
Old 09-02-2008, 01:44 AM
yeah i think you could get away in the winter... but dont hold me to it
Old 09-02-2008, 08:45 AM
sput's Avatar
Thanks Man I'll try that.
I would think you'd be fine. I'd recommend keeping an eye on your IAT2 temps though, you just don't want them ridiculously high. I can tell you that during the heat of the summer you definitely do need more efficient cooling.
https://www.cobaltss.net/forums/showthread.php?t=129820
and it's pre-set up for a dry 50 shot of nitrous It's supposed to be plug and play.
sput is offline
Old 09-03-2008, 06:19 PM
sput's Avatar
Sold.
sput is offline
TedSS
101
04-25-2016 10:46 PM
DevZX
09-16-2015 06:19 PM
Sean Cummings
09-11-2015 09:35 PM
BettyBlue2.2
09-10-2015 08:49 PM
09BlkCrusader
09-09-2015 04:47 PM
Quick Reply: FS: GM Stage 3 PCM / 06-07 Cobalts
