FS: LSJ Forged internals
Old 02-27-2009, 11:40 AM
Jazer's Avatar
Thats fine then. I've really been on here (frequently) for like a week or two, I have a boosted & built Cavy and have been on JBO for god knows how long, and my BF doesn't come on here that much.
We based the "price" on what he payed, around a year ago.
Sounds like it would be pointless to sell it with what he payed, probably just put it on our SS then.
Jazer is offline
Old 02-27-2009, 11:42 AM
stoon_cobalt_colby's Avatar
good choice i would remove it from u list of fs items ppl are gonna keep telling u its to high just keep it if u dont wanna lose that much
stoon_cobalt_colby is offline
Old 03-02-2009, 09:07 AM
Jazer's Avatar
Bump!!
Jazer is offline
Old 03-09-2009, 10:17 AM
Jazer's Avatar
Bump...
Still looking to sell:
Eagle Rods
TTR Stainless Valves
Diamond Pistons (ceramic coated) - 10.5 comp, stock bore
Total seal Piston rings
Jazer is offline
Old 03-09-2009, 10:24 AM
tityrous's Avatar
you are putting stock pistons back in? thats a steal for those diamonds originally 550is if i can remember correctly
tityrous is offline
Old 03-09-2009, 10:28 AM
Jazer's Avatar
Yeah... He bought an STI last week. I am buying over the SS.. I don't want much of a build for it. What's in my sig is whats going back in it, thats it. Nothin crazy for me.
He is taking a big loss on everything, but we need to sell them...
Jazer is offline
Old 03-09-2009, 10:29 AM
tityrous's Avatar
yea it might be worth it in the long run to just slap those pistons in it.... if not go with stock comp.. forged good luck on the sale though
tityrous is offline
Old 03-09-2009, 10:35 AM
Jazer's Avatar
If they were stock comp I would put them in. It would also be silly to upgrade the valves & rods if I am sticking with an almost stock car. Someone else could get a better use out of them.
I've tossed the idea around. The 10.5 comp would be alright with the dual pass heat exchanger Im putting on & if I just added meth injection. Stock pulley wouldnt be pushing it too bad. I just don't want another project car right now so it's a tough call. I've deff thought about it..
Jazer is offline
Old 03-09-2009, 10:44 AM
tityrous's Avatar
lol yea true
tityrous is offline
Old 03-09-2009, 07:12 PM
M88ArRamadi's Avatar
how much for just the rings?....intrested
M88ArRamadi is offline
Old 03-09-2009, 09:57 PM
  #36
StevesBlack06's Avatar
out of curiosity did you have eagle custom make you rods for the 2.0? those must have been pretty salty too bad the pistons are 10.5:1 id be all over em if they were stock comp.
StevesBlack06 is offline
Old 03-10-2009, 11:34 AM
  #37
Jazer's Avatar
M88ArRamadi - PMd
I don't believe the rods are custom made. (My BF purchased all of these.)
Jazer is offline
Old 03-10-2009, 02:37 PM
  #38
rods for the 2.0 are like 700bucks. i know eagle makes rods for tyhe 2.2 but not the 2.0 they wont work if they are for a 2.2 the wrist pin is different
Old 03-10-2009, 03:31 PM
  #39
Jazer's Avatar
They are the technically the 2.2 rods but he spoke with TTR before purchasing. They will work for the 2.0 but you have to use the 2.0 wrist pins.
Jazer is offline
Old 03-10-2009, 03:59 PM
  #40
the rod has to be modified for the wrist pin to fit... have you seen a 2.0 wrist pin compared the the 2.2? way different
Old 03-11-2009, 09:06 AM
  #41
Jazer's Avatar
All I know is he contacted TTR and asked them, and they sent him rods that they said would fit the LSJ...
Jazer is offline
Old 03-17-2009, 12:59 PM
  #42
Jazer's Avatar
STILL FOR SALE
See pg1 for details
Jazer is offline
Old 03-17-2009, 01:05 PM
  #43
crazyltd120's Avatar
will the internals fit an ls 2.2?
crazyltd120 is offline
Old 03-17-2009, 02:11 PM
  #44
Jazer's Avatar
I do not personally know what is and is not interchangeable.
The rods will work though, they are technically for a 2.2.
Jazer is offline
Old 03-17-2009, 07:14 PM
  #45
IF they have been modifed to fit the 2.0 they will no longer fit the 2.2 silly...
Old 03-17-2009, 07:17 PM
  #46
TurboTechRacing's Avatar
We did? Eagle does not make a off the shelf set of rods for the LSJ... That we know of?
Only rods we carry are for the 2.2L ecotec....
TurboTechRacing is offline
Old 03-17-2009, 08:52 PM
  #47
shadowfaxss's Avatar
Glad you chimed in Aaron!!!!
shadowfaxss is offline
Old 03-17-2009, 08:59 PM
  #48
I have never looked that "deep" into it, but I thought the rod length was different, along with the main and rod diameter bearing size? Isn't the 2.0L rods slightly longer?
Old 03-17-2009, 10:18 PM
  #49
I did not see a spec for the length of the rods and mind you, I have not taken a 2.0 or 2.2 apart but the specs in the factory manual for both is as follows:
2.0 2.2
Connecting Rod Bore Diam - Bearing End 2.0519-2.05252 in. 2.0519-2.05252 in.
Connecting Rod Bore Diam - Pin End 0.7877-0.7882 in. 0.7877-0.7882 in.
I see no difference in the specs for the two engines for bearing clearance etc. Compression ratios, as you know, are different. The stroke for the LSJ is not published in the manual.
Old 03-18-2009, 09:26 AM
  #50
Jazer's Avatar
All I know is that my bf called TTR and was told that the 2.2 rods would work for the 2.0 as long as he still used a 2.0 wrist pin. I do not believe the rods were modified at all, because he did not pay any extra for them.
Jazer is offline
Quick Reply: FS: LSJ Forged internals
