Wanted Innercooler, radiator, a/c condensor, and fan
I need the parts for a 2006 cobalt ss 2.0 sc. It has some front damage trying to get it back on the road any help thanks.
No, he is talking about the supercharger "Intercooler" located directly in front of the radiator and mounted to it by two plastic mounting brackets. I'm not really sure where to find it, if I see any I'll let you know. The part number is "GM PART #22720231" for the 2006 SC and comes up as a radiator if that helps at all. They have it on Gmpartsdirect, though it is around $200+.
Thanks man ive been told its both innercooler and heat exchanger not sure what the proper name is but it is tha one with the to plastic brackets on the side.
I'm not finding any right now, here's some info on the parts you are looking for though:
Radiator: 22717621
Intercooler Supercharger Cooling: 22720231
Fan & Shroud Cooling: 22718765
AC Condenser: 22696030
That is all the part names and numbers as GM lists them in the program if it helps any.
The GM part is listed as an intercooler, not a heat exchanger
Radiator: 22717621
