Wanted lsj brake conversion
Assuming you only want the fronts, but incase you want the rears https://www.cobaltss.net/forums/part...s-sale-299550/
Swapping everytime I race isn't a big deal. Im a auto technician. I have my own place. Not hard to do... trying to find local parts so I can pick up... not swapping my lnf setup. I'm keeping it
"Swapping is a waste of time" pretty sure the stock turbo record wouldn't be in the 11s if it were a waste of time. And Chris and Matt wouldn't be going 10's on a 17" wheel.
Rotors and calipers/pads are needed obviously. LSJ rotors should fit over LNF hubs, the hat should be wide enough. As far as lines I'm not sure if you need a different fitting from the Brembos to the conventional LSJ brakes. Send Chris a pm I'm sure he's got a list of everything you need.
