Wanted LSJ Engine block/trans blown up or scrapped or just plain cheap.
That's right. If you have an LSJ block that has a hole in the side of it or F35 trans with or without LSD in it, even if it has a hole in the bottom of it, I will take them off your hands. They don't HAVE to be blown up, but I don't want to pay $500 for a good block just to use it for this mock up. I only need one of each (One block and one trans). I will pay for you to ship them to me or even drive close to you to pick them up. Looking for some ASAP so if you have these scrap parts taking up room in your garage I will take them off your hands. The block doesn't even need to have pistons or rods in it. I would prefer a crank and oil pan, even if the oil pan has a baseball sized hole in it and the crank is snapped in half. I will still take them. If you have an LSD trans and the trans is destoyed, you can even keep the LSD from it. I just need the trans case and the input shaft assembly. I would also like the spacer that goes between the trans and engine. Let me know how much you would want for them. Thanks!
Bumpity.
Bumpity.
Last edited by StreetDreamz; 11-10-2009 at 08:20 PM. Reason: Automerged Doublepost
