For Sale LSJ>Engine, F35 LSD, S/C Kit and More! *Must See*
So, been a long while since I've jumped on the CSS.net. But I've got some goods for sale. I'll start with the small stuff/talk. I pulled a subframe and other stuff from a rollover, see first picture. I needed a few things, but couldn't pass up the chance to get the good stuff.
EVERY ITEM WILL HAVE A 3% add for Paypal, unless you pick up locally.
I'm located near Mankato, MN.
Only ship to continental 48 states. Items saying shipped are within reason, if my quote is too high, I reserve the right to PM you about some extra cost and we'll work it out.
So, the small stuff:
Hoses, coil packs, harnesses, fuel rail, ect... I mean it's everything connected to the motor, so PM me about those smaller things for now. See the pic of a pile of stuff.
ZZP Stealth HE: 10k miles, Slighlty bent mounting bracket for it to fit on my car, but everything is still in great condition. I tapped the top for Opt. B., something ZZP doesn't do without a added fee. These are $380 new+Shipping+tax.
$325 shipped
LC-1 Innovate. Needs new O2 Sensor is all I think... Pulled out of Wifes car to replace with Glowshift WB. $60 shipped.
P&P LSJ Throttle Body: $100 shipped Painted Red, needs to be redone at this point. Or goes to s/c kit buyer
LSJ Engine: 25k miles, see pics, just before roll-over had a new water pump and timing kit installed. Plugs look good, and valves all look good.
$1,800 + Shipping. Local Pickup>$1,650 discount for less hassle
F35 LSD Trans: 25k miles, spun by hand, lsd is working and no odd noises.
$900 + Shipping. Local Pickup $850
Want both together as you see in the photo? Special Price: $2,200
S/C Kit. I've gotta piece it together... Can get more info. S/C has 25k. Stock pulley. Rotors look great. Includes EVERYTHING YOU NEED, except a HE. Feel free to work out a price to add the Stealth.
$800+shipping
You need something, just PM me. I can see if I've got it in the pile somewhere and we'll work out a price.
Thanks,
Roger
Call/Text 480-263-3397 You'll get a much faster response this way.
Plugs pulled from motor:
$325 shipped
$800+shipping
Thanks,
Roger
List of items included in the supercharger kit price change down to $650+ship: Add $200 for the ZZP Stealth HE... otherwise find you own. Being I have been asked... Supercharger your 2.2 will take it from about 130whp stock to about 215whp supercharged
Parts:
Eaton M62 Supercharger(stock pulley 25kmiles) Include sensors, hoses, gasket, and bpv)
Get your own Injectors... Make sure you have correct harness
Stock LSJ Intake
P&P Throttle Body LSJ with bolts
Alternator bracket with tensioner stuff with bolts
Intake Manifold LSJ includes S/C gasket & intake gasket(used good condition), and MAP 2.5(LSJ) sensor, all bolts, uses stock endpalte still completely put together
LSJ IC Pump with hoses and T/overflow (Add $200 for ZZP Stealth or buy your own HE)
Stock LSJ Header
Stock LSJ Serpentine Belt
Things you need:
Injectors $140-200
Throttle Body Connector or some custom wiring work $Free-$15
Upper Radiator Hose- $10 used
Heat Exchanger $180-200 unless you add my Stealth $200 for mine.
Brake booster vac hose $10 used
NGK Copper Spark Plugs (Part# LFR6A-11) (Also one step colder) $12 new
A Tune via HPTuners. I recommend a custom tune for best performance and safety
Optional things to consider to buy yourself:
Windshield Wiper Conversion (Optional)
GM Parts
22729469 LSJ Windshield Washer Container
22732432 LSJ Wiper Cowl To Washer Container Hose
Exhaust:
Stock LSJ Downpipe or go aftermarket... exhaust isn't required to change at all actually
ZZP Triple Gauge Pod
Aeroforce Interceptor Gauge
GlowShift Vacuum | Boost Gauge
AEM Wideband Air | Fuel Ratio Gauge
Modular Pulley System>Need S2 Belt or Oversized Tensioner
Parts:
Stock LSJ Intake
Stock LSJ Header
Things you need:
Injectors $140-200
GM Parts
Exhaust:
You need to post pictures of every item you have for sale.
https://www.cobaltss.net/forums/clas...ifieds-274245/
But once it is open for so long, non mod/admin members loose the ability to edit posts.
You really should seperate everything. The photo of the pile of parts is not good quality.
Please let me know when you have update photos so I can fix this asap. I dont want to lock this on you.
I can edit it.
EVERY ITEM WILL HAVE A 2.9% add for Paypal, unless you pick up locally.
ZZP Stealth HE: Pending Payment
LSJ Radiator with Fans: $220 Shipped
P&P LSJ Throttle Body: $100 shipped Painted Red, needs to be redone at this point. Or goes to s/c kit buyer 100k miles Pulled from my running Cobalt.
LSJ Engine: Pending Payment
S/C Kit. $650 + Shipping OBO
List of items included in the supercharger kit price change down to $650+ship: eing I have been asked... Supercharger your 2.2 will take it from about 130whp stock to about 215whp supercharged.
Parts:
Stock LSJ Intake
P&P Throttle Body LSJ with bolts Unless it sells above
Stock LSJ Header
Upper Radiator Hose
Things you need:
Injectors $140-200
GM Parts
22729469 – LSJ Windshield Washer Container
22732432 – LSJ Wiper Cowl To Washer Container Hose
Exhaust:
PICTURES!!! WOOT
Thanks,
Roger
Parts:
Stock LSJ Intake
Stock LSJ Header
Upper Radiator Hose
Things you need:
Injectors $140-200
GM Parts
Exhaust:
PICTURES!!! WOOT
Thanks,
Roger
09-28-2015 12:51 PM
