For Sale Tvs, coilovers, rsfs, exhaust, meth, retro, plus a whole lot more! 35 items total
i have a lot of parts for sale. if you want any other pics of something let me know. all prices are shipped within the US. Canada will be extra.
Name - Jon Campana
Location - Altus , OK
Means of Contact - PM me here
i am going to try my best to do first come first serve. so whoever asks about something first then they have priority.
adjustable belt tensioner brand new never used - 100
[IMG]20150318_013646 by jonnyc127, on Flickr[/IMG]
dual steering column bezel gauge pod has some cracks in the paint. to be perfect it would need to be sanded all the way and painted thats why it is only 60 and not 90 – 60
[IMG]20150318_030408 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_030515 by jonnyc127, on Flickr[/IMG]
20150318_030523 by jonnyc127, on Flickr[/IMG]
carbon fiber spoiler could be re-cleared. bottom corners are chipped. cant see it when installed. - 130
[IMG]20150318_005410 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_005459 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_005535 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_005547 by jonnyc127, on Flickr[/IMG]
steering rack spacer - 15
[IMG]20150318_013714 by jonnyc127, on Flickr[/IMG]
4 coil packs with harness - 50
[IMG]20150318_013625 by jonnyc127, on Flickr[/IMG]
60# injectors with harness - 120
[IMG]20150318_014518 by jonnyc127, on Flickr[/IMG]
MPS pulley 2.8 with hub - 55
[IMG]20150318_014425 by jonnyc127, on Flickr[/IMG]
WOT box w/2 step - 140
[IMG]20150318_011007 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_011013 by jonnyc127, on Flickr[/IMG]
stock h.e. coolant neck - 15
20150318_015632 by jonnyc127, on Flickr[/IMG]
hawks hp plus front brake pads. used but a lot of pad left - 80
[IMG]20150318_011632 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_011707 by jonnyc127, on Flickr[/IMG]
red fuel rail cover, needs re-painted - 15
[IMG]20150318_013735 by jonnyc127, on Flickr[/IMG]
Zzp s3 Heat exchanger – 150 SOLD
Tvs 8k miles with 2.8 pulley – 1650 SOLD
Arm rest comes with arm rest, bracket, cup holder, and the bolts i used to install it – 90 SOLD
custom retro headlights with 6K HID's, red halo's and audi style led's. not the best condition and only lows work but that is why they are cheap – 175 SOLD
meth injection kit comes with the 2.5 gallon tank, pump, enough line to go from trunk to engine, check valve, 7gph nozzle, throttle body spacer, and all wiring. it uses a hobbs switch. currently set at 10 psi. – 200 SOLD
devils own meth nozzle holder and 12 gph nozzle brand new never used. - 40 SOLD
Name - Jon Campana
ark DT-p coilovers with pillow ball strut mounts have about 10-12K miles on them. paint is chipping and some surface rust but the work perfectly. i never had an issue with them- 600
[IMG]20150318_021040 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_021058 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_021134 by jonnyc127, on Flickr[/IMG]
fog light hids 5k with relay harness – 60
[IMG]20150318_015238 by jonnyc127, on Flickr[/IMG]
brand new magnaflow cat. 2.5" $65
[IMG]20150318_010441 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_010449 by jonnyc127, on Flickr[/IMG]
used stock transmission mounts no rips or tears. $20
[IMG]20150318_010313 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_010317 by jonnyc127, on Flickr[/IMG]
Chilton manual for 05-07 Cobalts. covers have marks but all pages are there and not torn
$15
[IMG]20150318_010650 by jonnyc127, on Flickr[/IMG]
brake caliper speed bleeders, pn 639560 for front disks. brand new $10
[IMG]20150318_010751 by jonnyc127, on Flickr[/IMG]
brake caliper speed bleeders, pn 639520 for rear drum, brand new $10
[IMG]20150318_010805 by jonnyc127, on Flickr[/IMG]
used TTR engine mount. has about 5K miles on it. $120
[IMG]20150318_005750 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_005808 by jonnyc127, on Flickr[/IMG]
stock shifter cable bracket from 06 ss/sc $15
[IMG]20150318_010736 by jonnyc127, on Flickr[/IMG]
gas pedal, pn 22731157 fits and 2005-2010 cobalt $80
[IMG]20150318_011136 by jonnyc127, on Flickr[/IMG]
2.2L injector rail with injectors and harness, brand new. $50
[IMG]20150318_011113 by jonnyc127, on Flickr[/IMG]
[IMG]20150318_011122 by jonnyc127, on Flickr[/IMG]
set of 20 used lug nuts from my 06 ss/sc. have wear but still work. $15
[IMG]20150318_010337 by jonnyc127, on Flickr[/IMG]
EVAP purge valve. pn, 12597567 $15
[IMG]20150318_010156 by jonnyc127, on Flickr[/IMG]
ottp stage 2 rotated mounts with solid bushings - 150 SOLD
stock length engine belt, not sure if used or not but i couldnt see any rips or tears $15 SOLD
K and N stock replacement air filter $35 SOLD
$15
ottp oversized tensioner pulley - 15 SOLD
zzp shorty header has v-band end welded on. you can easily remove it and have the flange smoother and use the 3 bolt flange - 120 SOLD
3” downpipe 2.5” exit high flow cat w/wideband bung has v-bands on both ends to match with header and cat-back - 150 SOLD
2.5” cat-back with magnaflow resonator and muffler has a v-band in the front to match with downpipe. - 250 SOLD
brand new Return Style Fuel System For LSJ - 500 SOLD
red foglight halo's and inverter – 15 SOLD
these are the best pics i have of it installed... i no longer have the end caps though....
[IMG]10083_10152913529725523_861129979_n by jonnyc127, on Flickr[/IMG]
[IMG]945618_10152913529425523_1131933876_n by jonnyc127, on Flickr[/IMG]
[IMG]966502_10152914192170523_611285693_o by jonnyc127, on Flickr[/IMG]
