For Sale Vertical Door Inc Lambo Door Hinges
i know you want retrofits but i have the all black second gen headlights with hids??? the only thing wrong is that the bar and three dots dont light up havent had time to look why but the halos do and their bright... heres a pic of them
Can you measure the distance between the bolt holes top to bottom on the door side and the hinge pillar side for me please.
I called vertical doors but they just wanted to Sell me an HHR set, but the guy said to Measure and see just how close of a match they were from your Cobalt to my HHR.
He said the Cobalt set supposedly used a heavier shock like 7 something while the HHR used a 5 something. I told him a heavier set would be good for me. Then he said, but you might not be able to pull the door closed then, thats when I said ahhh but I have 3 layers of Dynomat on my doors making them heavier. lol
Thats when he said to measure the distance between bolt holes.
Oh and have the Holes been Modified in any way like elongated or drilled larger?
Thanks
Thanks
the bracket that mounts to the door measures as follows:
space between bolt holes 3-3/4"
space between top bolt hole on upper door mount bracket to lower bolt hole on lower door mount bracket 17-1/4"
the brackets that mount fender side measure:
1-1/4" from center of each hole.
the distance between the upper and lower mounting holes is 13-3/4"
#37
I'm currently hooking up my glowshift wideband gauge, once thats done i'll start measuring up my doors hinges.
#44
Thanks for taking the measurements for me on these.
Before I even got around to check my HHR, a member on the HHR Forums sent me a link to a guy selling a set of HHR direct bolt on lambo door kit. Turns out he never even installed them. And now decided to trade his HHR in on a new car so he put them up for sale.
They come with the shocks,bolts, door wire extensions. Seller emailed me the PDF install instructions. "Lambo Doors Inc." is all they have on them Brand wise.
So these will go on come Spring.
GLWS
Bump for you.
GLWS
Bump for you.
