I missed the loud growl of my SRI
Old 09-14-2008, 10:51 PM
  #101
nramlow2006's Avatar
Originally Posted by 07MONTECARLO_SS
grand prix guys will remove drivers side headlight and run em too.
tru dat.. if i had a fog Assembly it would be removed
nramlow2006 is offline
Old 09-15-2008, 12:03 AM
  #102
Ramphex's Avatar
Originally Posted by Chevy Cobalt 08
Ok guys I converted back to the original GMPP intake with the blue filter. HOWEVER I did a slight modification. Instead of the air resonator, I replaced it with this:
Now instead of have wasted money on the pipes, I still used them! Basically I'm replacing the air resonators job with pretty much no restriction. It's still not a CAI but it's still pulling in cooler air. And the reason for the black thing at the end is so no water drips in from the crack where the headlight sits.
Sorry but I think that's just stupid... just leave the CAI the way it was
Ramphex is offline
Old 09-15-2008, 12:17 AM
  #103
actually that isnt that bad of an idea.. now if the guy takes out the fog light and couples the pipe to the opening. he will have a true ram air intake...
trust me... ill be the first to knock him for stupid ****.. this is actually not that bad of an idea
Old 09-15-2008, 12:18 AM
  #104
SS_Ry's Avatar
agreed
SS_Ry is offline
Old 09-15-2008, 12:23 AM
  #105
chevy cobalt 08's Avatar
Originally Posted by iLLmaTic3s
interesting man..if ur look to get more air flow..run some pipe to the grille section of the front bumper..some ghetto but functional ram air..
That's pretty much as close as I was able to get. But I want fog lights so I won't do that
chevy cobalt 08 is offline
Old 09-15-2008, 01:49 AM
  #106
I'm old school
Halfcent's Avatar
I can't see the open end of the airbox supply pipe, but it looks like it's either buried against the back of the facia or has some kind of cap on it. Where does that pipe open up to?
Halfcent is offline
Old 09-15-2008, 03:33 AM
  #107
Cause it's close to the facia. Like I said above, that black thing is just to prevent rain water from getting into the pipe from the crack of the headlight opening. It's not against the facia though. The end is open freely with no obstruction.
Old 09-15-2008, 03:35 AM
  #108
Ramphex's Avatar
I don't get the point of all that though? CAI would do the samething with less restrictions and probably even colder air
Ramphex is offline
Old 09-15-2008, 03:49 AM
  #109
oh my god..... reading<you big time.......
Old 09-15-2008, 03:50 AM
  #110
Ramphex's Avatar
Now do you know what you said there, buddy?
CC08: reported
Ramphex: good stuff
Ramphex is offline
Old 09-15-2008, 03:58 AM
  #111
I'm an idiot huh? I missed the sound of the SRI I didn't like the CAI. So I put the SRI back. But instead of wasting money by not using the pipes I bought I put them to use by mimicking the air resonator with the pipes which basically does the same with less restriction and more cooler air. IF you had read, I said that no it's not as cool as a CAI would be, BUT yes it definitely grabs cooler air than it would with or without the resonator. The gmpp intake is made to work by forcing to suck air thru a hole in the bottom of the air box. It leads to the pipe I put in there. So now it's sucking from the fender. And cooler air. So who's the idiot now? It's called USING MY HEAD.
CC08: reported
Ramphex: good stuff
Wow grow up. You even went and deleted calling me an idiot cause you know I reported you. !!!
Last edited by chevy cobalt 08; 09-15-2008 at 04:07 AM. Reason: Automerged Doublepost
Old 09-15-2008, 09:54 AM
  #112
what if we stopped wasting the moderators time and only reported important things...
actually ram air from a cold air source is a tad bit better then a cold air intake. see on are cars the cold air intake will only get you with in 4 degrees of ambient temp. a ram air is not only forcing air into the intake via the pressure cause by the speed of the car but is creating a direct supply to outside air. if you want i can go out to my car and run a data log to prove this..
that would be the point of that.
Old 09-15-2008, 10:00 AM
  #113
If I raced I could easily hook the pipe up to the fog light but since I don't I guess I could leave it how it is but at least I HAVE the option.
Old 09-15-2008, 10:06 AM
  #114
If I raced I could easily hook the pipe up to the fog light but since I don't I guess I could leave it how it is be at least I HAVE the option.
very true not to mention you think your intake sounds sick now.. wait till you standing outside of a car that has the intake running to the fog light assembly loud as hell
Old 09-15-2008, 10:21 AM
  #115
nutsandboldts05's Avatar
I like your current set-up CC08. Just ignore the ignorant ass holes that are calling you names.
I may try to do something similar but run the open piping to a grill opening or somewhere to grab more air.
nutsandboldts05 is offline
Old 09-15-2008, 11:54 AM
  #116
That's pretty much the best location I can get. Pipes aren't bendable lol. And also the more bends the more air flow restriction as well.
Old 09-15-2008, 11:56 AM
  #117
iLLmaTic3s's Avatar
get bendable pipe from like autozone or something to reach to the grille area
iLLmaTic3s is offline
Old 09-15-2008, 11:58 AM
  #118
no.. because then you will be picking up heat off the radiator
Old 09-15-2008, 12:09 PM
  #119
iLLmaTic3s's Avatar
not really..u will be surprised..not going into detail..but just puttin it out there
Old 09-15-2008, 12:21 PM
  #120
BULLETSSMOKE's Avatar
If you missed the loud growl you should go https://www.cobaltss.net/forums/how-guide-43/how-make-nice-cai-123118/ <<< there Gmpp intake converted into a CAI, and its super f'ing loud. with more power
BULLETSSMOKE is offline
Old 09-15-2008, 12:38 PM
  #121
Originally Posted by BULLETSSMOKE
If you missed the loud growl you should go https://www.cobaltss.net/forums/showthread.php?t=123118 <<< there Gmpp intake converted into a CAI, and its super f'ing loud. with more power
uhh lol i followed your how to remember i asked you if i was missing an elbow? Mine wasn't super loud. Maybe it's because of your exhaust.
Old 09-15-2008, 12:49 PM
  #122
Scythe_Snake's Avatar
Man the threads on css.net just get better and better. Bottom line dude, do what you want, but using parts just because you don't want to "Waste the money" isn't the greatest idea. Just think your parts out next time.
Scythe_Snake is offline
Old 09-15-2008, 12:51 PM
  #123
iLLmaTic3s's Avatar
true..it can be a headache on trying to make something custom when u cud of just bought a injen cai like i told u in the first place
Old 09-15-2008, 02:05 PM
  #124
Brraaapp's Avatar
Holy Wire LOom Batman!!!! I know RObin.....I know.
Brraaapp is offline
Old 09-15-2008, 02:07 PM
  #125
Ramphex's Avatar
CC08: you got owned in my intake topic
Where exactly did I get owned?
I got a "ram-air CAI" anyway so who cares :-)
Silly LS bumper
Ramphex is offline
Quick Reply: I missed the loud growl of my SRI
