LSJ shift light cought on tape!!
if it sees you are not at WOT it will come on in early RPM then towards the red zone RPM
It comes on for you to shift for better fuel economy. I personally take it close to the red area then shift when it comes on.
99% of the time I do not pay attention to it. I just shift around 3-5 range normal driving.
THATS BEcause if you drive like a normal person you dont have that problem... when you hammer on it it comes on at 6,000-6,400and when you drive like a normal human it comes on at 3000 3500
1 Post
Ok so i've figured out it comes on in the MANUAL cobalts ONLY.
The 2.2's for gas mileage and engine redline.
The 2.4's at the rev limiter.
The 2.0's, well, never until you go over 7400 rpm.
i think its just different for each car... mine doesn't come on at the rev limiter
#37
#41
#44
I've seen the light before a couple times. I was sort of powershifting when the tac jumped to almost 8K when I did it. I about **** my my pants too since I really didn't want any bent valves and a destroyed engine.
#45
I was flat shifting on the way to mohegan sun today, right before redline cluch shift. not letting off the gas at all, no tach jump but no shift light :-(
I have seen mine come on before tho when ive hit potholes lol
#46
I have a 2.2L and I never stated it comes on ALL like that. Just stated when it came on for my car.
When not at WOT it comes on in lower RPM as well as upper RPM. At WOT it goes a little farther, but to the point where it says hey ******* you may want to shift before you bounce off the rev limiter. It comes on maybe 300-500 RPM before the rev limiter. I really wouldn't know never bounced off the rev limiter except once and that was because I accidentally mis shifted going down the track. Whoops.
#48
the 2.2L shift light on mine comes on if i'm driving in 4th at 40mph....it seems like it just stays on...even at normal driving speeds...it shouldn't come on at 2kRPM...damn those GM bastards (07 cobalt 5spd)
#49
It's coming on to tell you to shift for better fuel economy.
