Ralliartist loves Holset
Old 11-30-2010 | 03:41 PM
  #76
Area47's Avatar
Rent me! per hour
do you know what the green and white marks on the inducer are?
a machine shop lacks the ability to rebuild that turbo, or any turbo for that matter.
i'll put this very simple. if the bolt was removed from the shaft with a ratchet, it's most likely bent. it takes very little torque to throw the main shaft off. you won't see it with your naked eye, but the balancer will at 50k+ rpms. if there is a finger print on the carbon seal, it will never seal.
Old 11-30-2010 | 04:17 PM
  #77
ralliartist's Avatar
Yes sir!
Old 11-30-2010 | 04:29 PM
  #78
Area47's Avatar
Rent me! per hour
im actually being nice. passing along some personal experience from when i used to rebuild them.
Old 11-30-2010 | 05:52 PM
  #79
cmiller8006's Avatar
Originally Posted by ralliartist
Nah man, you ain't bothering me.
Pushing for 600whp, obviously 10sec quarter mile with that much power. I'm more of a drag racer, so if I get to 10s without using that much power, no problem.
The car is in Nebraska, I'll be driving it up to Michigan to ZZP for tuning. I'll probably put it on E85. But I'll have it tuned for regular gas too. There is no E85 here in Germany, but I'm still not 100% sure that I am going to bring it over here.
I'm going with a Clutchmaster Stage 4 clutch, 6 puck sprung. That way it's not too harsh on the street but it still got enough clamping for the power that I'm making.
The car is going to be built to behave like a normal stock car when driving around town, and then get violent when I want it to. ZZP stage 2 turbo cams (much milder than the stage 3s, better for idle and cruising), fully race ported head (well over 300cfm intake side/200 exhaust side), ferrea oversized valves, zzp valve springs, la sleeves, wiseco pistons (stock compression, stock bore).
We'll see how many passes I can make before they realize I don't have a cage.
I love my stage 4 CM's. I am always on other forums and there are srt's running 10's full weight at 420whp. Gives me something to look up to lol.
Old 11-30-2010 | 05:57 PM
  #80
Slicks of course, probably big ones since the power level will be so high. I'm thinking Hoosiers 26x9.5. I already have drag bags in the rear suspension. I'll add some limiting chains up front. There is no reason the car shouldn't cut some great 60s with that setup.
Here is something else I found also, might get these and give them a shot next year.
Darrell *** Racing - Drag Straps (Powered by CubeCart)
Old 11-30-2010 | 09:25 PM
  #81
Perfect.disguise's Avatar
Never noticed that myself, thanks for the link..
Old 12-01-2010 | 12:58 AM
  #82
I understand. Thanks for all the insight.
Old 12-01-2010 | 01:00 AM
  #83
Those look pretty nice compared to the chains.
Old 12-01-2010 | 03:03 AM
  #84
Area47's Avatar
Rent me! per hour
competition engineering has the same thing, for about half the price.
Old 12-01-2010 | 06:06 AM
  #85
I can't find it on their site. Got a link?
Old 12-01-2010 | 09:20 AM
  #86
troyss's Avatar
That seems like something you can make from an hardware store
Old 12-01-2010 | 10:00 AM
  #87
True That. but, I spent a 100 bucks on my drag bags, this is only 100 bucks also and it should help out tremendously with 60fts. Sometimes, if it's not expensive, it's nice to just buy the kit since it comes with everything all nice and neat.
Old 12-01-2010 | 12:32 PM
  #88
I am sure you could. But if you seen my attempt, it worked well but didnt look pretty lol.
Old 12-01-2010 | 07:25 PM
  #89
Area47's Avatar
Rent me! per hour
they are buried in the catalog. had a set of em about 5 years ago. just never used em. so i sold em
Old 12-02-2010 | 02:10 AM
  #90
I found them on Jegs. About 57 dollars.
Old 12-02-2010 | 02:21 AM
  #91
LS6Rally's Avatar
^ Link?
Old 12-02-2010 | 06:14 AM
  #92
Competition Engineering Front End Travel Limiters - JEGS
That's the competition engineering ones. I still like the DCR ones though because they look easier to install. No welding required.
Old 12-02-2010 | 07:01 AM
  #93
jimbos'ss's Avatar
hey did you guys get much snow? we got 11 inches here in graf lastnight.
Old 12-02-2010 | 08:38 AM
  #94
Nah, we didn't get much, like half an inch maybe. A couple nights ago we got like 2 inches.
Old 12-07-2010 | 04:01 AM
  #95
D1sclaimer's Avatar
I got 4 inches right here.
Oh wait... Nevermind.
Old 12-07-2010 | 02:28 PM
  #96
LOL, snowing here today, roads are TERRIBLE!
Old 12-10-2010 | 04:17 PM
  #97
D1sclaimer's Avatar
Nebraska weather is clear and 50 degrees.
Old 12-10-2010 | 06:00 PM
  #98
It's been below 30 for several weeks now and snows everyday. Today was a little warm in the mid 30s and everything started to melt. At least it doesn't get below zero here like it does in nebraska.
Old 12-11-2010 | 03:22 AM
  #99
D1sclaimer's Avatar
True dat.
When are you gonna put all this together and beat my 700whp when I get retuned in March?
Old 12-11-2010 | 04:25 AM
  #100
LE5_AJ's Avatar
yea no **** does it blow 40mph every day like it does here?
