idle problem
Old 08-10-2008 | 10:22 PM
fst07ss's Avatar
idle problem
I have an 07 SS/SC with GM stage 2, cold air intake and 2.85" pulley. The problem I'm having is when I drive the car with the AC on and release the gas pedal the idle fluctuates up and down 1k rpm, It sounds like the car is going to stall. With the AC off it runs fine. I brought the car to my local Chevy dealership, they told me "it's not covered under warranty because of the stage 2 (wich they installed), the car may have been abused causing it to have irratic idle". I think thats a bunch of BS.. but what can I do? Anyways.. I would like to know if anyone out there has experienced this problem.. and what you did to fix it. Any advice will be truly appreciated. Thanks in advance.
Old 08-10-2008 | 10:29 PM
Stouffer's Avatar
Search there is a sticky somewhere.
Old 08-10-2008 | 11:03 PM
Coblasts's Avatar
There is a reflash for that with the older models but I would of thought for the 07 they would of included it in the main flash for the pcm. When they flashed your stage 2 you didnt get the add ons for that problem.
Old 08-10-2008 | 11:07 PM
YellowRocketSS's Avatar
I have the same problem. but i rarely use my ac so i dont bother with it
Old 08-10-2008 | 11:52 PM
rukkee's Avatar
There was a updated flash as someone stated earlier , but i would make them warranty it as it is a GM kit that is covered by your cars warranty . The 2.85 throws a wrench into the warranty thou, put the stage 2 pulley back on and make them fix it. If they wont call GM customer service ,or take it to another dealer.
You can try cleaning the throttle body out , but the symptoms point to the stage tune.
Old 08-11-2008 | 11:09 PM
fst07ss's Avatar
I figured it had something to do with the stage 2 tune, but wasn't 100% sure. I cleaned the throttle body, it didn't do much, the problem is still there. I've had so many problems with this car since day 1, guess I'm just going to deal with the idle problem for now. I plan on trading it in next year....
Thanx for the advice!
hacadacalopolis
10-28-2015 07:09 PM
tomj77
10-04-2015 12:39 PM
jimbofug007
10-02-2015 01:06 PM
DocSvensk
09-27-2015 03:24 PM
Adiaz1ss
09-27-2015 12:51 AM
