throttle body wiring help
8 Pin
Throttle Actuator Control (TAC) Module Pin
Wire Color
Circuit No.
Function
A
D-GN
485
TP Sensor 1 Signal
B
L-BU/BK
1688
5-Volt Reference-2
C
BK
2752
Low Reference
D
PU
486
TP Sensor 2 Signal
E
YE
581
TAC Motor Control - 1
F
BN
582
TAC Motor Control - 2
G
GY
2701
5-Volt Reference-1
H
BK/WH
1704
Low Reference
6 pin
Wire Color
Circuit No.
Function
A
BN
582
Throttle Actuator Motor Control (2)
B
YE
581
Throttle Actuator Motor Control (1)
C
TN
2752
Low Reference
D
D-GN
485
Throttle Position Sensor (1) Signal
E
GY
2701
5-Volt Reference
F
PU
486
Throttle Position Sensor (2) Signal
Wire Color
Circuit No.
Function
A
D-GN
485
TP Sensor 1 Signal
B
L-BU/BK
1688
5-Volt Reference-2
C
BK
2752
Low Reference
D
PU
486
TP Sensor 2 Signal
E
YE
581
F
BN
582
G
GY
2701
5-Volt Reference-1
H
BK/WH
1704
Low Reference
6 pin
Wire Color
Circuit No.
Function
A
BN
582
B
YE
581
C
TN
2752
Low Reference
D
D-GN
485
E
GY
2701
5-Volt Reference
F
PU
486
^ Wow, I didn't expect the rewiring to be that straight forward... you just split the two reference wires and then attach them to the appropriate terminal...
holy crap this came in good timing LOL. been asking Hunterkiller and other people what to do cause i bought the same adapter for the lsj TB. paid like 70 bucks... looks like i should of just rewired my stock one cause i gotta do rewiring anywayz...
so dont worry about two extra 2 wires on the adapter??
i got a pic on my build, click in my sig. the adapter still has 8 wires, thought it would of had 6.
Here's a quick diagram of what you need to do:
As for driving in Neutral.. Hmm..... ???
... Or perhaps you mean when you DISengage (press) the clutch, or are in Neutral. And yes my car randomly searches for RPMs too at idle. It's a common problem caused by a dirty throttle valve. I plan on cleaning mine tomarrow acually. There is a howto or sticky about it somewhere on the sight.
