06 Cobalt SS 2.0L Stock Radio wont turn on.
Ok so i switched out my battery today and when i went to start my car up everything worked but the radio. I checked the fuses and they all work so i dont know what happened. the is no power to the radio it wont play, the clock wont work and my cds stuck. Any info will help.
-Thanks
-Thanks
If powering it up after removing the fuse doesnt work it may end up needing a radio. Sometimes theyll come out of it. try unplugging the radio and waiting like 10 minutes and plug it back in and try again. Ive had that work before testing for that same problem. The fuse by your battery is probably the 150A Mega fuse. Basically what supplies the power to your fuse blocks. Saves your wiring if you accidently jump start it backwards and things of that sort.
Ive unplug my radio and let it sit and Ive taken the fuse out to let it sit for like 15 min but it didn't work and now i just found out that when changing a battery if you don't let it "decharge right" the radio will think its getting stolen and lock itself up sooooooo now i need to pay $50 for a GMC certified technician to to unlock it.
Ive put in alot of batteries in my day as a Certified GM tech and have never heard of that, or had a problem either. Come to Sioux Falls, SD and I'll do it for nothing!
Actually I'd do it for a Wendy's Frosty, its hotter than hell here!
He's talking about like that 90's JDM **** where the radio locks you out, lol. Basically, that doesn't happen anymore anywhere.
If you need a stock 2006 SS Radio, I got one that you can have for $40 shipped to your door.
Very good. Almost mint.
Here's my for sale thread: https://www.cobaltss.net/forums/part...-radio-282240/
twilson380
09-14-2015 10:52 AM
shawnsseries
09-10-2015 08:29 PM
