07 Cobalt Coolant
For you, I don't believe so. On lsj's, it's more important to determine how cool the charged air is after it's been cooled in the intake manifold. We measure this temperature change with a secondary map sensor known as the IAT2 sensor (Internal Air Temperature 2). The IAT1 sensor is integrated into our MAF sensor (which you have as well). Knowing and comparing the two temperatures lets us know if the s/c system is heat-soaking or operating normally after various driving conditions (normal, idle, WOT, etc.). Because 2.2 and 2.4 vehicles didn't come from factory s/c'd, I don't see any way of adding a provision for the pcm to read an IAT2 sensor. I could be wrong though. It's been years since I've followed up on any progress for s/c builds.
Dex is orange, even the 50/50 mix, too many people add water, this is a big no no, you only add water to the non pre mixed one, and only between 30% and 50% should be water. Too much water causes rust and corrosion, do not use more water than 50% in your cooling system.
Considering basically every part of the motor that the cooling system runs through is aluminum, rust would not be an issue
No, You will get rust by using only water, I have had to flush mine intensely due to the stupidity of a dumb mechanic adding water instead of coolant. I had plenty of rust water and the coolant reservoir is now rust brown on the inside, even after a good radiator flush, so please, do not say rust will not be an issue, when it clearly will be. Car Engines are not made from aluminum, otherwise they wouldn't way a as mush as they do, would they? Please consider the entire cooling system, not just parts of it, such as, metal hoses, the radiator, coolant temp sensor, thermostat, there is plenty of places water can cause rust there, especially if your radiator is not in "perfect" shape. There is a reason why "rust inhibitor" is added to coolant, you don't think they add it for nothing, right?
GM Family II engine - Wikipedia, the free encyclopedia
@ OP
Please, do not add too much water, they tell you coolant is best for a reason, use it, lol.
well, if you want to get technical, you're correct. By definition, rust refers to iron and steel. But it can corrode, and that's what I mean. You're making it seem as if aluminum is impervious to corrosion when in fact it's not. And having pure water without dex-cool (possible any coolant) can cause it to form "white rust". Now, as for the radiator, I'm not sure if it's made out of aluminum as well, but if it's not, then you will run the risk of rust flaking off and getting into areas where coolant travels.
#36
Exactly, this adds up to mal-functioning thermostats and sensors and even causing blockages, this could end up overheating your engine causing so much damage, you will be slapping yourself because of repair bills up to $1000 and more, simply because you added too much water, or didn't buy the $15 bottle of coolant. If the coolant was $40, I'd buy it still, beats hundred dollar repairs... Wouldn't you?
Besides, I think there is much galvanization going on in there, so any surface damage, such as a bent radiator, would instantly result in rust and corrosion, rust water is corrosive and it will coat your entire cooling system in rust.
#38
Im going to use the dexcool concentrate Prestone. Then going to mix it 50/50 with distilled water.
So what are the steps for doing a coolant flush and re-fill then? Is it just drain out old stuff, put in new stuff like an oil change or is there more to it? Thanks (07 2.2 N/A) if that matters.
#39
Aluminum does rust in a sense, just not the way that iron does. When aluminum rusts (Oxidizes) it forms a hard coating on the outer perimeter. This coating actually acts as a protective barrier, and this why it takes aluminum so long to disintegrate.
