07 sc wont start problems help
my 07 s/c wont stay started it turns over like normal then just cuts out if you hit the gas to try to get rpms up it doesnt do anything no throttle response at all i dont know whats wrong with it its throwing a cel but i dont have a cat so it always throws that i tried undoing the battery letting it sit still nothing i dont know what to do or whats wrong any ideas or suggestions?
i have ottp header 3 inch cat back gm stage 2 injen intake zzp 2nd intercooler exedy hyper single brembo front brake swap short throw port and polished super charger and eibach springs i have the interceptor as well my a/f has been high i beleive latley too
idk its sitting at a shop now i can check later on ill have to scan and see what comes up it was weird cuz its been running fine then i parked it and went to start it would not stay running just dies turns over like normal though
jcatauro,
Is the shop you referenced in your last post on the thread an independent shop or a GM dealership? If it's the latter, let me know if I can follow up with them for you.
Regards,
Sarah
GM Customer Service
Regards,
Sarah
GM Customer Service
It's an independent shop I will prob take it to a dealership though I don't know what to do or to check for it won't stay running it just randomly happened so I don't know what it could be
Just for something to try.
Unplug your O2 sensor so that the car will go into closed loop and run on set tables instead of looking at all the sensors.
If this works to keep the car running then a sensor is the issue..
Got to be throwing some kind of code though,post them when you get them!
roth
09-26-2015 12:16 PM
