08 chevy cobalt jumped time !
I just bought this cobalt 2.2 was missing a lil so hooked up computer to it and it said tha cam and crank sensors were bad so bought new crank sensor put it in fixed nuthan drove it a lil than one day I started clanking like metal to metal **** so did reseach on code it was spitting and told me car jumped time and it wasn't lieing so tore down motor chain was stretched and tenchioner was bad so replaced them retimed motor now won't run only started once idk what todo can someone help me
freakta (02-07-2016)
Unless the beige guide breaks its probably impossible for the chain to jump time. It is possible with a broken guide and a bad tensioner for the inlet cam to have enough slack to retard enough to kiss the valves. That means low/no compression and Italian Joe is correct, compression test first.
it takes 74980 or so revolutions to line up the sprockets with the colored links if you have them. Best to to what Italian Joe suggested. If you replace the head you need new timing stuff anyway make sure you take the car apart with the crank at TDC and the exhaust lobe on #4 cylinder at 2 o clock and the inlet cam lobe on #4 cylinder at ten oclock roughly then follow the book for installing new parts. good luck with your issues
