08 COBALT TC rear caliper rattle
So this has been going on for a while my right rear caliper has been rattleing for the longest time and it goes away when ebrake is pulled up slightly or the brakes are applyed I was told that it was the caliper is bad but before I replace it I'd like to get your guys opinion..
Your caliper isn't bad, it's the pad(s) rattling around on the caliper bracket. I've had this problem before and after putting on new calipers. On my car is was a two part problem, 1) over time the pads wear grooves into the caliper bracket allowing pad room to rattle around and 2) a lack of lube wear the pad meets the caliper bracket.
I replaced the caliper brackets on my car, that cured about 80% of the rattle and re-lubing the pads every couple months took care of the rest.
So I should replace the calipers then just keep up on living the caliper brackets I don't think I can get just the brackets
Okay that will be my mission for Thursday.. what would you guys recommend for pads and rotors all the way around I was told OEM is the best
I have not yet but I have question for the senior members on here isn't there supposed to be brake hardware between the pads and the caliper bracket so they don't wear them?
The pads sit directly on the caliper bracket. Some cars, not Cobalts, have a thin steel clip/shim that clips onto the caliper bracket and the pad sits on that clip/shim, see pic.
[IMG][/IMG]
[IMG][/IMG]
Dustin24
10-08-2015 09:15 AM
QuickSilver_SS
09-17-2015 05:38 PM
QuickSilver_SS
09-17-2015 11:23 AM
