2.0L suppercharged versus 2.2L natural aspirated
Hi all, i have a supercharged SS with a blown piston and a scratched cylinder, i also have a naturally aspirated 2.2L ecotec, I'm wondering if anyone can tell me if those 2 engine blocks are interchangeable ?
Mr. D (07-29-2017)
The bare blocks are interchangeable but like Slowbalt2000 said the crank trigger wheel is different. As long as your head is OK and you are still using an LSJ head the cam sensor is in the head so you don't have to worry about that. As long as you use the LSJ crank 2.2 block will work. However you will no longer have piston oilers or an oil cooler.
