2006 Cobalt LT 2.2 engine swap 2.4
I have a broken 2.2 engine and I have available to me a cheap slightly used 2.4 engine that came out of an 07' HHR.
I've been researching and can't find much about it, but what different would I need for my cobalt If I were to put the 2.4 ecotec in instead of the 2.2?
New ECU? Or anything?
I would gues its a identical motor other than the piston and cyl size,all connectors and harness should plug right in.
But the tune for the 2.4 will be different,you should get the ecm and the harness with the motor though to be on the safe side.
shawnsseries
09-10-2015 08:29 PM
