2006 L61 overheating
Ok so input a new motor in an 06 LS. Motor was out of an 05 Saturn Vue. Put a new t-stat in and filled it full of coolant. The hose from the top of the radiator to the head gets hot, as well as the return line to the top of the res. tank. The hose from the t stat housing to the lower radiator, and the heater hoses do not get hot, and of course the car has no heat.
Any ideas or suggestions are appreciated, thanks!
Most likely an air pocket somewhere. Cause if your not getting any heat that means that your not getting any coolant flow through the heater core. You may have gotten a bad t-stat. Is it throwing a cel? Possible bad waterpump as well.
ThoR294
10-04-2015 08:44 PM
