2008 code P0011
2008 code P0011
Hi, I have an 08 SS Turbo that started throwing code P0011 and my code reader says it is Cam Position Actuator A - Bank 1 - Timing Over Advance.
I was wondering what it will take to replace this Actuator. Can it be done at home, or is it a trip to the Dealer?
I believe thats is right on top of the motor. I had to change solenoid on the motor but heres a thread. I looked at.
https://www.cobaltss.net/forums/show...522&styleid=10
Its a helpful thread.
had this problem on my LNF also. 90k miles
bought the Exh and Intake Cam solenoids off Amazon since they were prime and cheaper than Crate Engine Depot.
10 mm socket. Takes 5 minutes to do. they are located on your VC towards the passenger side, the cylinder looking objects.
I hate to suound stupid but I was looking at the engine and with all the sensors I can't tell which ones they are. Could someone take a picture and post it for me?
This is the 2.0 turbo lnf
tuned08SS is that your car? What brand upper charge pipe is that? I like the way it dosen't go over the engine. I have the hood insulation and there would be clearance issues with the ones that go over the valve covers. Mine is stock right now but a friend got a Solstace GXP and is going to mod it so I have to step up. If I get a different intercooler that I see on ebay, does it have the charge pipes? Also do you like the CAI under the hood? I have seen them routed outside the engine cmpartment.
OrangeCoba
09-25-2015 06:06 PM
