2008 front right turn signal won't blink
I have a 2008 Pontiac g5 2 door coupe
when I installed my projector headlights it seemed like my right turn signal stopped working
I get the 'fast blink' on the dash
today I switched the bulb and that didn't fix it
left turn signal works
both rear signals work
right parking light turns on but won't blink
I've read of switching the hazard relay switch behind the dash?
or new bcm?
anyone else ever have this issue and fix it?
or new bcm?
Start checking wires, make sure they are all connected - easy to knock something loose wedging the lights back in......
You could try plugging the stocker back in, see if the signal works again - if it does, you may have a bum socket on the new light.
blinker fluid is full...
maybe ill try that
I always thought I was using the old sockets but I just checked the back of my oem headlight and the sockets are all there
would corrosion in the socket make it light up but not blink?
I have the same issue. Its weird af because the light will turn on...just wont blink. Been like this ever since I bought the car used but I dont know jack about electrical so I havent bothered
Since you tried swapping bulbs already, my money is on a bad connection or a defective "vely hi quarity" made in China light.
Good luck!
