Alignment help
Alignment help
Going to start off by saying I know absolutely nothing about alignments. I took my SS in for an alignment today, and about 30 minutes later, they came out and told me they needed to drill my strut because they couldn't adjust the camber as much as they needed as is. Now to me, this just doesn't seem right. Why would you need to drill something to get more adjustment? He asked me if I hit something or if I hit a huge pot hole. I told him no, but I just get the car, so not sure if something happened before I got it.
In addition to drilling the strut, the also said I needed a shim kit on the LR, to get it set to what it needed to be. This alignment went from $69 to $350 lol. Does this seem right to you guys? Here's the sheet they gave me.
Drilling out the strut bolts is standard procedure for gm if it is out of spec. Also the rear on these cars is unadjustable so yes technically a shim would be needed but there are 6 bolts that hold the rear subframe on and you can loosen them and shift the rear end until its in spec.
$280 to elongate a hole sounds pretty steep to me. I remember doing it on a grand prix that had no camber adjustment and it didn't take that long at all. Why does it say cobalt except ss, sport on the top of your printout?
I didn't notice until I got home that it said except SS. Are the specs a lot different?
They charge you what flat rate calls for. If service info says it takes one hour, thats how much they charge. Could take them 5 minutes or 5 hours, thats just how flat rate works.
The ss specs arent a whole lot different but they are different none the less
For the rear to be out that much, the axle may be bent.
Are you getting excessive tire wear on the left rear? Steering wheel off center/vehicle pulls?
I'd address the rear toe first, as it will matter the most. The front camber, while excessive, isn't bad and won't be noticeable to you when driving. It will actually improve handling but at the cost of slightly higher inside edge wear on that tire. Seeing that the other side is excessive as well (-1.7 is still a lot), I'm assuming the car is lowered? How different are the ride heights, fender lip to ground, from LF to RF? If the car is a little lower on the right the camber will be higher. Could be a simple sagging spring causing that.
Need more info here to give a full recommendation, but I would address the rear toe first and go from there, the shims work but on a rear disc car I don't like them, it puts the rotor out of parallel with the cailper bracket and leads to uneven pad wear.
Find another shop that knows what they're doing. They should offer to install a camber bolt kit and be done in 20 minutes.
You can't shim the rear. The only way to fix that is to replace the rear axle beam.
DANRICKARD
10-01-2015 12:08 AM
