Annoying AC fan noise...
Old 01-22-2009, 01:13 AM
IROCZ0r's Avatar
Originally Posted by Maven
You have to remove the cover(break off plastic heat rivets) theres nuts under that, then you need to remove the nuts and cut out the blower. Or you can spray some electrical llube in their. Ive used CRC Switch lube with good results, also several different brands of dry film lubes.
Someone should do a How-To with pictures, seeing as how this is such a common problem.
I'm not incompetent, but I am not the most intuitive at working around problems on my own. With a fairly detailed walkthrough, I'm sure I and anyone else could do this.
And then we'd feel a whole lot better about our Cobalts.
Old 01-22-2009, 03:44 AM
megaman311's Avatar
i took mine to the dealer. they told me that it was a defective blower motor. so i got a new one under warranty and no more noise.
Old 01-22-2009, 10:12 AM
IROCZ0r's Avatar
Many of us are out of warranty now though, myself included.
Old 01-22-2009, 10:21 AM
no_mo_tires's Avatar
Originally Posted by Project Freeze
i have the same noise now too on settings 1 and 2.... dealer told me it's normal wear and tear.
your dealer kinda sounds sucky....no offense , If my dealer told me that I'de slap their silly ass.
You can pull the blower motor and lube it, or deal with it
beat me to it you bastard!
sometimes the dealer will try to say they replaced the blower ^ this is all they are really doing most of the time.
Originally Posted by 06SIBLT
its the blower motor, you can pull it out and replace it, the dealership did mine, although they replaced it and said that when they turned it on the pulley made the shroud go square like so they replaced that too. They had my car for 4 days!!!
we were both late lol
Old 01-22-2009, 10:23 AM
averagewhiteboy's Avatar
You bought an economy car. They make weird noises.
Old 01-22-2009, 10:25 AM
SuperchargedSS's Avatar
My 06 SC did this, so far my TC has been great but I am sure it will come back as well. Talked to the dealership about it..... "No fault found"
Old 01-22-2009, 10:29 AM
I have had a suspension squeak since my car was new.. But somehow it always stops when I take it in.. lol. Too bad I don't live at the dealership because I'd never have the problem! I have a few random squeaks and stuff.. But **** happens.. I'm not driving a Mercedes.. And PA roads blow..
Old 01-22-2009, 12:30 PM
Maven's Avatar
Youre right.....someone should make one.
My blower doesnt make noise, so I am not cutting my car open for no reason( I am not that altruistic)
Old 01-22-2009, 01:56 PM
Great tip. I did use a dry film but couldnt get in far enough. I just sprayed close enough and hoped for great results from a half assed job, nope.
What really is annoying is that the dealership won't do this for you.....
Old 01-27-2009, 12:46 PM
snake890217's Avatar
can I spray lube in where the cabin filter is using like the little tube thing that attaches to the end and get it from there?
Old 01-27-2009, 12:57 PM
  #36
Maven's Avatar
I wouldnt recommend it, youd jsut be randomly spraying lube into the fanb blades, not getting it on the motor shaft where it needs to be
Old 01-27-2009, 01:10 PM
  #37
okay figured that was too easy lol
so wahts the best way to break those bitch rivets off? lol
Old 01-27-2009, 01:54 PM
  #38
HeavyRightFoot's Avatar
I had that noise back in Oct.
I took it to the dealer (under warranty) and they fixed it.
They said the blower motor just needed to be lubed.
Quiet ever since.
Old 01-27-2009, 02:24 PM
  #39
mines not under warranty... As simple as it is you know the stealerships... $$$
Old 01-27-2009, 04:12 PM
  #40
Maven's Avatar
Screwdriver, chisel or stiff putty knife and a small hammer.
Old 01-27-2009, 04:16 PM
  #41
light'bolt's Avatar
Seems like those 05's had that problem. Had mine fixed about 2 yrs ago. Hope it not getting ready to go bad again...
Old 01-27-2009, 05:13 PM
  #42
Well I've got an 05... anyway this thing sucks, I chipped away at those rivets and still holding on. that's all for now, its too cold. If I can get the damn rivets off I'll be glad to try and make a how to. IF i get it off. For now all the banging seems to have moved things to not squeak, but when I hit a bump I know that'll change. Im thinking to get a large bit and drill them out, then tap the hole and use screws/bolts to hold it after.
Old 03-02-2009, 08:50 PM
  #43
IROCZ0r's Avatar
Bumping this in the hopes for a how-to, as my fan noise has become louder since I started this topic. I can now hear it over my music at 1/4th volume. Now even trying to turn up the music to ignore the problem doesn't work!
Old 03-02-2009, 09:20 PM
  #44
Big E Canada's Avatar
Mine is doing this now, bringing it in for service this week (was covered under warranty)
Old 10-12-2009, 09:59 AM
  #45
1BadBlueSS's Avatar
Mine is doing it now...will attempt to fix myself.
Old 12-04-2010, 03:12 PM
  #46
1BadBlueSS's Avatar
Sprayed silicone in there and it helped for about 5 minutes. HELP!!!!!
Old 12-05-2010, 08:47 PM
  #47
Maven's Avatar
Car is 3yrs old and now does it on low all the time.... if I fix it ill post up pics.
Old 12-05-2010, 11:28 PM
  #48
This thread will come alive for the next 4 months lol P.S. mine's back
Old 12-06-2010, 12:21 PM
  #49
BlueStang's Avatar
Just one of the many proplems with a Cobalt
Old 12-06-2010, 07:26 PM
  #50
08SSTCRD's Avatar
Originally Posted by afireinside7710
mine does the same thing on setting #1 (card in bike spokes), im going to get it looked at soon under warranty, woot warranty!
Thats what mine does as well. Slightly annoying but not horrible.
Quick Reply: Annoying AC fan noise...
