Any fellow Toronto people?
Hey I'm looking for some help with some issues I have been having with my 07 ss s/c. Wondering if anyone local could lend a hand? Will follow up with details if I get a response. Thanks
hey man thanks for replying. Yes a few codes. Most persistent is p0172 running rich followed by p1011 i believe is the code ( intake air flow preformance), and usually get a p2261( bypass valve mechanical). Maf Map Tps appear good on scanner from what Ive read. I have checked for vac leaks and checked all wires. Had pcm flashed, checked fuel pressure, changed air filter, bypass valve actuator is working, purge solenoid is working. Making full boost but does feel a little laggy. Im at a loss dude.
I'm not really that helpful as I only got into the car after I got a turbo but have you cleaned your maf? How's your throttle body doing? Honestly someone who knows what they are talking about please chime in, I just saw you were local so I responded to hopefully get more eyes on
