bcm ???
bcm ???
Took my car to the shop cause I was having electrical problems they say its my bcm if I buy another one do I have to have it programmed or is it a install and go part look forward to your info thanks
well, does any air come out of the vents, or does it not blow at all? The wipers do go through the bcm......but I would check the multi-function switch also.
Im having so many problems with mine, my wipers wont come on at all, my heat and air controls are stuck in one position, and my power steering is it...hope the bcm fixes yours i am taking mine into the dealer next week
Before replacing the bcm unplug the connectors and remove it.
Take a good look at the pins and connectors for burning or discoloration and corrosion(ones that don't look like the rest or blue or gene in color)
Spray the pins with contact cleaner and apply some dielectric grease to pins and connectors and reassemble.
Alot of electrical problems are caused by poor connection or corrosion on the pins due to salt water intrusion.
The electrical system consist of low voltage and any type of increase in resistance causes problems.
