BIG Problem!!!
Old 04-12-2008, 04:45 PM
JBomm's Avatar
i was stuck at work... screw that place!
Old 04-13-2008, 12:05 AM
JBomm's Avatar
its not the coil pack or the spark plugs!!! what the hell is the problem?
Old 04-13-2008, 04:04 PM
JBomm's Avatar
I rechecked the fuel system by turning the ignition to the on position so the pump will give pressure the fuel rail to see if I purged it fuel will squirt out. I did this 4 times and nothing at all!
Old 04-13-2008, 08:19 PM
wordsthatiwrote's Avatar
Since its not the spark plugs, I suggest checking the spark plug wires. But it honestly still sounds like a bad Coil Pack. Take the pack off and I believe a place like AutoZone or Murrays can test them. Im kind of sure you can run a mutlimeter on it to test it also.
Need to examine the entire ignition system. Maybe check fuses and relays if applicable.
Old 04-13-2008, 08:24 PM
HackAbuse's Avatar
There are no spark plug wires.
Old 04-13-2008, 08:33 PM
duh, IM a ******* tool. I just got off of work and Im just looking to take my mind off of bills.
Maybe the terminals inside the pack are not making a good connection with the plugs.....Cause as far as I know, which isnt much, coil packs slam down on top of the plug....? xD
Old 04-14-2008, 02:57 AM
JBomm's Avatar
I rechecked the fuses and found one that I missed, injector fuse. Replaced it but the car still runs like crap. It sounds like a helicopter. I have been working on it all weekend with some help from halfcent also, but no fix. Tomorrow I will be taking to a shop to get checked out. This sound like a problem for the pros.
Old 04-14-2008, 03:19 AM
TheYellowSS's Avatar
Originally Posted by JBomm
high winds and COLD! So I thought since the fuel was really low that the gas froze in the fuel line so I went to fill her up.
Freezing point for gasoline is around -40 °C to -60 °C, it wasnt that cold outside.
Just for future reference
Old 04-14-2008, 04:55 PM
JBomm's Avatar
0 deg C is 32 deg F
But the car is in the shop so lets see what happens. I will post later of the the results.
I ended up being the coil pack, WTF! Just can't believe it, I swapped it to another car. Oh well it is fixed!
06MetallicBalt
08-17-2021 03:40 PM
brandon04
10-21-2015 07:04 AM
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: BIG Problem!!!
