Bleeding the brakes
Bleeding the brakes
I cannot seem to get the brakes to bleed no matter what I do. I am doing it using the method in the how to thread, but the pedal remains soft no matter how many times I go through it. This is not the first time I've bled the brakes, but it is the first time I have had this problem. Does anybody have any insight as to what I could be doing wrong?
Rear: 639520
I miss my OEM wheels since I could bleed the brakes with the car on the ground reaching through the bars.
OP.
Ive never had an issue but sometimes it takes a good deal of time.
I added info to the rear brake thread, but nothing about bleeding.
But here they are: get power bleeder pump system. Add a good amount of fluid to the pump if you are adding new fluid. Find the correct spacer with the kit that will fit on the stock resevoir cap snugly. Pump bleeder to 10 psi or so and mach sure that it holds pressure. This will insure the cap is tight and there are no leaks in the system. The seal at the cap was my main issue initially. Then you begin bleeding. I went ahead and put new fluid in. Bleed each corner until new clean fluid comes out.
LR RF(Inboard) RF(outboard) RR LF(inboard) LF (outboard)
I'm no mechanic and took my time. Was simple.
LR RF(Inboard) RF(outboard) RR LF(inboard) RF (outboard)
I had this same issue man. try resetting the position of the rear calipers. when I did it it made the pedal feel hard again!
Take both calipers off. Use a Needle nose plyers and screw in both calipers until they cant go no more. Grease pins and put them back on. Go inside the car and lift the ebrake a few times.. Start the car take it for a ride.
Let me know if that helps.
