Blower went out need help.
Old 11-17-2010, 03:13 AM
flyy's Avatar
So I was letting my car idle to warm up since I'm in England and had the heat on 4 and apparently somebody from my work went out and turned my car off while the blower was still on. I'm guessing this is why my blower went out. My question is can I fix this easily with a few bolts and a kick or does it call for more precise hands which i don't possess?
Old 11-17-2010, 03:32 AM
MT0911's Avatar
I'm not sure I understand correctly. So you were letting you car warm up and you had the fan set on 4 speed and then someone went out to your car and turned it off and now the fan is not working? If I am correct, that is no reason to why it should not be working now.
Old 11-17-2010, 05:30 AM
metalmedic's Avatar
Check the fuse... ur blower shouldnt brake just because the car was turned off that don't make any sense...
Old 11-17-2010, 05:41 AM
cmatthewb101's Avatar
x2 on both post above
Old 11-17-2010, 06:26 AM
HunterKiller89's Avatar
check fuse, if fuse is still good, then try and power the blower motor directly to see if the motor itself is still working. If its still working, you have a short somewhere. If it isnt working, replace it
Old 11-17-2010, 07:05 AM
flyy's Avatar
they turned the car off with the blower still on, that doesnt effect it at all? and i will check the fuse.
Old 11-17-2010, 09:09 AM
2.2balt's Avatar
Shouldn't affect it at all. If anything, you're blower motor would be making noise on speed 1 if it was getting close to death's door lol
Old 11-17-2010, 09:10 AM
xxxxsh4d0wxxxx's Avatar
No, it's fine, I do it all the time.. Not on purpose, it just happens..
Old 11-17-2010, 09:26 AM
mccullj's Avatar
my **** has been squeaking since like a month after i bought it. everytime i take it to the dealer, they say they can't hear it. even when it is loud as **** and i take them out to the car and say, do you hear that, its loud as ****. they reply...i don't hear anything at all. it only does it on speed one and two. so don't expect any help from the dealerships. i have had 3 different dealerships in 3 different states tell me this. even when my dad, who is a gm engineer, has complained about my blower motor being loud when he is riding in the car with me. WTF??
Old 11-17-2010, 10:19 PM
scottie's Avatar
Mine was obnoxiously loud while on 1 and 2 for maybe six months when I first bought the car. Though about taking it out and seeing if I can grease something up perhaps, but just stopped over time.
Old 11-18-2010, 04:32 AM
flyy's Avatar
so i checked the fuse and the fuse is fine so what could it be? its not making noise at all when i turn it on 1 2 3 or 4 so WTF IS UP!
Old 11-18-2010, 09:29 AM
dspeed123's Avatar
Check for power at the blower motor harness. If you have juice then its the motor.
Old 11-18-2010, 09:53 AM
Eurasianman's Avatar
Great. Mine makes a wear noise on speed 1. My car has only 12,000 miles on it and it's not even a year old...
Even better. This is going to be fun when I take my car in to the dealer next month. And my crap gets louder as well if I start driving with it on speed 1. You can even hear it over the music
*skeptical*
Old 11-18-2010, 10:00 AM
Phyrric's Avatar
Haha I thought you meant the supercharger blower
Old 11-18-2010, 10:07 AM
Baron7700's Avatar
how / why do you have a cobalt in the UK???
Old 11-18-2010, 03:33 PM
Old 11-18-2010, 06:58 PM
Coblasts's Avatar
Not to be a dick but the heater isn't set to off is it,if it is the blower won't work either.
Old 11-18-2010, 07:45 PM
heathkidder's Avatar
i thought he meant the sc blower also...are u just talkin about the a/c?
Old 11-18-2010, 11:58 PM
the blower...the thing that blows air? including hot air, so no, not the AC
its a part of the HVAC system
Old 11-21-2010, 09:31 PM
flyy's Avatar
It's the a/c and heater blower not a supercharger blower and I have a cobalt in the UK because im in the USAF so they shipped it over with all my stuff.
Old 11-28-2010, 03:59 AM
flyy's Avatar
So where exactly is the hvac blower located in my car?
Old 11-28-2010, 04:48 PM
dspeed123's Avatar
Under the glove box
Old 11-28-2010, 05:21 PM
flyy's Avatar
Originally Posted by dspeed123
Under the glove box
ok thank you
Old 12-01-2010, 09:14 PM
IGotABalt's Avatar
mine doesnt work at all either, i know that it makes heat but just doesnt blow the air out. I gotta fix it asap too bc it started snowing this week and its freezing out too!!
Old 12-04-2010, 02:28 AM
flyy's Avatar
well i just ordered a new relay so ill get back to you and tell you if that fixes the problem, i can tell you though to use a voltage light and check you fuse and relay in the passenger side floor board to the left there is a panel you can pull off and there are a bunch of fuses and a fuse puller in there. the blower fuse is the very top right fuse on the fuse box and its a 10 amp. the relay is the only big black relay in the center of the fuse box. should say delphi on it but you cant check that which is stupid i think. so check the 10 amp fuse first then look under the glovebox and find the wires where the blower is they should be right on front. and use the voltage light to check for power in those lines.
Quick Reply: Blower went out need help.
