Blower went out need help.
Old 12-04-2010, 12:32 PM
IGotABalt's Avatar
well i know that my blower is gettin power so i think that i may have a bad blower. Somereason I cant figure out how to get the blower out though...
Old 12-04-2010, 01:24 PM
IGotABalt's Avatar
well i figured it out, the connector from the wiring harness to the motor was all melted like it had gotten hot. I think if i just get a new connector it will fix the problem.
Old 12-04-2010, 02:49 PM
HunterKiller89's Avatar
let us know how it goes. Glad you found it
Old 12-04-2010, 03:42 PM
IGotABalt's Avatar
well only connector i could find was through the stealership and they wanted $50 for a little connector...so i just cleaned up some of the melted plastic. Put some conductive silicon in there and hooked it up and its working now as a temporary fix. I just dont wanna pay $50 dor a connector...
Old 01-25-2011, 06:28 PM
Lavanimal's Avatar
I have an extended warranty that I just used to have the a/c blower motor replaced in my 2006 Cobalt SS. The blower motor and the control unit on the center console had both burned completely out due to some electrical short. The new blower sounds way out of balance, and started making an extremely loud noise, like something is contacting the blades as it spins. Particularly severe at highest setting of 4. Also noticed that after the dealership had worked on my car, the airflow out of the left center vent is blocked when in heat mode, but flows freely in cold mode. Is it there some type of actuator cable for the airflow baffles that direct air through the vents that might be flexing into the blower fan? Why does a brand new blower sound so much worse then the old one (when the old one worked)? When I put my hand on the base of the blower, it feels like the bearings are grinding.
Old 02-03-2011, 04:28 AM
flyy's Avatar
i still dont know whats wrong with it.. ive replaced the relay checked the fuse and even gotten a new control unit the last thing i know to do would be to buy a new blower all together
Old 02-03-2011, 09:34 AM
dspeed123's Avatar
Just order the replacement blower. If I remember right it was like $120 or something for the kit. You will have to do some cutting of plastic to install the replacement blower motor. I think it took all of an hour to replace.
Old 02-03-2011, 10:21 AM
csementuh's Avatar
You happen to know a GM part number or a source to get said kit? My GF's 08' LS is making an annoying sound from the blower motor, so it would be nice to replace it.
Good luck to the OP!
Old 02-03-2011, 11:11 AM
dspeed123's Avatar
$107.13 from GM Parts Direct. If I remember correctly the part# was 25776197.
Old 02-03-2011, 11:59 AM
csementuh's Avatar
^ thanks!
turbochargedss2012
09-20-2023 12:17 PM
Silverbullet333
10-04-2015 02:27 PM
jimbofug007
10-02-2015 12:06 PM
09-30-2015 07:22 AM
goaliemo
09-28-2015 01:37 PM
Quick Reply: Blower went out need help.
