boost pressure stock?
check the health of your engine.
pay particular attention to the boost solenoid control; if the cross shaft of the boost control valve is seized from age , especially if you have run methanol/water mix injection, the butterfly will bleed off boost as the actuator cannot close it( as the shaft is seized)
Other issues with an SC include belt slip....
good luck.
good luck.
good luck.
good luck.
okay, ill go up to 10, then it goes down to 9, and stays there. but im also just looking at the gauge, so it might be off. lol
we had some srt4s, and some had boost leaks, so im guessing this might be the same problem.
Last edited by SalvageBaltSS; 02-24-2013 at 11:15 PM. Reason: Automerged Doublepost
