bouncing idle
bouncing idle
A couple of days ago i installed a header and catless downpipe. At first the car ran just fine, but after a little test drive the check engine light came on which was no surprise because i did a sensor delete without getting the code removed (the sensor in the downpipe). Along with it though came a bouncing idle.
It revs to about 1200 rpms then falls to 800 rpms and does this continuously. At first the "bouncing idle" happend whenever the car was not in gear. But now when i come to a stop the car idles fine. The problem still occurs when I coast in neutral though. Any advice?
My coolant light also came on even though my coolant is where it is supposed to be in the reservoir. Im not sure if the two problems could be related or not
Bouncing Idle: Known commong problem
See
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/idle-problem-cure-finally-116051/
See
My idle is getting better if anything. I know its not getting worse. This problem developed the day after i did the header install so i figured it would have something to do with that
It seems to me that the cai on our cars suck ass. My friend's does the same thing. He can be doing 30mph and put it in nuetral to let it coast and it revs up and down like crazy
[QUOTE=Erick161;5051194]yup, when the car isnt up to temp it acts like its wants to stall. Never has, just dips down to like 500-600 rpm when i engage the clutch...anno
Yupp
no wat hes sayin is to clean ure throttle body bc alot of times with the cai being routed soo low it picks up water...oil from the filter and oilly air in general, and some sludge can get back up as a cause form this so hes sayin to clean outt the tb and I would recommend a catch can to prevent somin lke this from happenin again...i bought my greddy from ebay it hooked right up and been wrking wonders
Yupp
Does it only do it when your A/C is on? Mine did then I took advice from the thread posted above and cleaned my throttle body. Idles completely fine now.
Do you have an aftermarket intake? if so...
Good to hear i need to do mine
ok guys i figured it out. When i did the o2 sensor delete i forgot to tape up the wire. So it just dangled there until it shorted out on something. When it shorted it blew my emissions fuse. taped the wire and replaced the fuse. good as new
