Brake Fluid Change
Brake Fluid Change
So I went to Mr. Tore and they are telling me my brake fluid is bad. WTF. Never heard of changing brake fluid but what do you think. They said it gets Copper in the lines and starts making the brakes bad? Should I listen to those guys?
Don't forget, brake fluid does pick up a lot of heat from your brakes, even though it's just hydraulic fluid, it does wear out with time and does need to be changed for the best performance and life of your brakes.
^^^ This, plus it picks up moisture from the air (even that little bit that gets into the resevoir) and water boils at a much lower temperature than brake fluid.
Water in the fluid, a bit of hard braking, and it feels like your stepping on a sponge as your car hurtles off the edge of the track, brakeless
I just did mine at 60k miles. Everything i drained looked like sludge. It's actually a simple procedure to do yourself but it's freaking messy and time consuming to when refilling/bleeding. They aren't jerking you around.
