BREMBO brake caliper question
is there a way to tell if the caliper itself is "bad" or not, issue i am having is that the inner pad on the drivers side wore out signifigantly faster than the others, i am currently at a little over 30k miles on the pads where i got almost 45k outa the last set, i havnt yet had the caliper off the car but took a look with it on and saw no leaks or obvious damage and only the inner pad is sitting on the squeal bar rest arnt even close, not real sure what to look for here other than a sticking piston(how do you check that) or maybe a bent pin that holds the pad. any ideas? lemme know before i throw a new caliper at it for no reason thanks guys.
BTW oem pads acdelco oem rotors
I'm going to check this tomorrow I didn't use new pins when I replaced the brakes they were in great shape and came right out so I lubed them and put them back in I'm wondering now if that was a mistake
DANRICKARD
10-01-2015 12:08 AM
