Can't go into any gears
I just finished putting my transmission and new clutch in the car not too long ago and finnally started up the car and it idles good and everything seems good, when the car is off it will go into every gear, but when the engine is on it's locked out of every gear, the only thing ive had trouble with was bleeding the slave cylinder and the pedal doesn't feel how i remember it used to be, could the slave not being bled properly result in this issue of the gears not going in when started? and also if anyone knows a good way to bleed the slave cylinder id love to hear it, i bled the thing like 10 times already.
Hopefully is just that this is the second time I took off the tranny first time to change out the clutch an then I put everything back on bleed the clutch and car turn on but will not go no where I could go into any gear wit out pressing on the clutch so I took down the tranny again and the tob was stuck so got that and put it back and now this so ima try and bleed the clutch and brakes tomorrow
