Car doesn't start/Turn Key and nothing happens
Old 03-03-2011 | 04:32 PM
Sandantos's Avatar
I've searched for this for 2 hours or so, and haven't found the exact same problem.
It happened when I left work, the weather hit -35c or so that night..the car started fine, i left work and stopped for gas. Fueled up, tried to start the car , and nothing.
While turning the key halfway, the electronics come on as normal, but as you turn it all the way (to ignition/start), nothing happens. The key turns fine, everything powers on (lights, radio, etc) but it doesn't wanna ignite/turnover.
When you turn the key, no sound, no clicks, nothing. It's not the battery, as I just replaced that a few weeks ago, and know what a dead battery behaves like. It's also in my garage and fully charged right now (got it towed home).
I've checked all the crank/ignition fuses (4 or 5), they're all fine.
I've checked the fuel cap also, as that came up on some threads as the problem.
I'm wondering if it's the starter or ignition sensor or solenoid.
Any input would be appreciated.
Old 03-03-2011 | 04:34 PM
ssblackstealth's Avatar
corn gas ftw....
press the clutch in lol
jk man never ran into this issue
Phyrric's Avatar
Something like this happens to my friends honda, all the power and stuff worked, we changed the sparkplugs and all that, but it turned out that there was a piece of rubbing blocking the clutch from being fully depressed, so the car wouldn't start
Old 03-03-2011 | 04:41 PM
Sandantos's Avatar
I appreciate the suggestions but mine's an LS and automatic....
Old 03-03-2011 | 04:43 PM
shoes-780's Avatar
that has happened to mine,it was a lose post in the main fuse box, mine was the positive. happened twice then found it
Old 03-03-2011 | 04:45 PM
outtamymind's Avatar
check the 2amp passkey fuse in the bcm. if its blown thats your problem. happened to me and a few other people i know. its a pain in the ass to actually fix the issue that causes it.
Old 03-03-2011 | 04:54 PM
Studmuffin02's Avatar
same happened to me, we pretty much checked every fuse for ignition and crank. In the end, it ended up being in the fuse box. we switched I think the ignition crank with the fan, the secondary fan that is. (when your car hits 200degrees in coolant temp the fans turn) Haven't had a problem since, should probably get a new one though lol.
Old 03-03-2011 | 05:04 PM
RA040424's Avatar
How do you tighten the posts on the fuse box? I think I may be having an issue with mine.
Old 03-03-2011 | 05:05 PM
shoes-780's Avatar
i think a 11mm wrench or do it compton ass terry style with visegrips,lol
Old 03-03-2011 | 05:07 PM
Sandantos's Avatar
Amazing.
I pulled those fuses earlier, the run/crank and starter ones, opened them and looked...they looked fine.
I swapped both of those with the matching fan fuses......
Car works.
I owe ya man, I gotta get some new fuses I think and probly replace em all, since I don't know which one was screwed.
*Edit, for future reference, I swapped out both crank relays with the fan ones Relay # 12193604. I'm gonna replace them all I think, unless I can figure out which one was bad.
Old 03-03-2011 | 05:14 PM
RA040424's Avatar
haha! I'll just try tightening it with my teeth.
Old 03-03-2011 | 05:42 PM
Originally Posted by Sandantos
Amazing.
Car works.
Yeah it's definitely sketch driving around with some bad fuses on the car ha. I need to do the same as well. Should be under warranty but who knows what GM will do for us. And no problem man, glad it helped.
Old 07-19-2011 | 03:34 PM
m_beauford@hotmail.c
Guest
Posts: n/a
Same thing helllppp
I am having the EXACT same issue however mine is a manual.. I have tried to jump start it and checked the fuses for ignition crank as well.. I havent had a chance to check the fuse box because it happened yesterday and couldn't get a tow.. I live in tx it is hot as well as mine is a 2007 LS possibly think it could be the same thing..? I know its not the battery or alternator.. I know what cars do when it is.. I have never ran into this issue with a car ever..
Old 07-19-2011 | 03:37 PM
MastaShaKe_88's Avatar
this happened to mine, and was the LAST thing in a list of things to happen before i towed my car to the dealership and they replaced my crankshaft sensor
chefhhr
10-26-2015 11:36 PM
Gugi96
09-15-2015 01:24 AM
The Rookie24
09-14-2015 08:03 PM
jthwjde
09-07-2015 10:24 AM
Infamous SC/SS
09-04-2015 06:33 PM
Quick Reply: Car doesn't start/Turn Key and nothing happens
