Car has problem starting
well my car has a problem starting it takes a very long time to start its juss wont like turn over or sumthing. i started thinging maybe i need a new battery and spark plugs and stuff like that. also my car seems to start smelling like fuel alot. btw its a 2007 pontiac g5. if it is a electrical problem i have a 1200 watt amp 2 10 inch kicker comps, pioneer avh p-4000 2 tvs in the headrest and underglows as well as 2nd gen dual ccfl projectors
If the car is turning over real slow when you try to start it or it doesnt tun over at all(you will hear a clicking noise) then the battery would be suspect.
If its turning over fine but not starting for a long time I would say the plug need tobe changed.
it could be an injector and/or regulator related problem if your smelling a lot of fuel. i know gm has had a few problems with them leaking and causing a long crank issue.
F
F
Getaway_Driver
09-08-2015 09:41 AM
