Car Wanders and pulls hard to the left
For a few weeks now I have noticed my car wanders on the highway. it will randomly pull to the left and then pull back to the right. I have to keep correcting it or run the risk of it smashing into someone. It randomly started happening and I have not hit the curb or anything.
I had an alignment done and they said my toe was off, but it was adjusted and he said everything looks good.
I also noticed that when I accelerate like normal, ie <5 of boost the car will pull to the left and when I let off it will go back to being straight. I know what torque steer is but this never happened before
Any Ideas?
Any Ideas?
Any Ideas?
Any Ideas?
That's under normal driving conditions though. As soon as I got on the gas pedal(half throttle) the steering wheel really jerked to the left and like I said, I know what torque steer is because the car has basically full bolt-ons and Trifecta tuned at 23psi but it wasn't torque steer. I have to turn the steering wheel quite a bit to the left to make the car go straight. I'm sure torque steer had a factor in it now because I'm getting on the throttle but something else seems to be the problem. I brought it back to them(GoodGuys) and the mechanic reevaluated it and said that the alignment is perfect but he thinks my rackin pinion is bad because he adjusted it and the steering wheel is barely moving.
However, unfortunately it was running ok if I stayed off the gas pedal so I sold it. LOL It is back in the normal position now but when you get on the gas you have to turn the steering wheel to the left to keep it straight. The buyer was fine with it so I never fixed the issue. I just sold it like that. Not sure if it could be your rackin pinion but I guess it's a start?
Nah no tire rotation. That was my next step. I checked the front tires to see if there were any issues and they looked good.
I dont know, he said it was pretty significant amount and that my camber was a little off but that was due to my lowering springs.
Getaway_Driver
40
09-10-2015 09:11 AM
Getaway_Driver
09-08-2015 09:41 AM
