car want stay running
when you go to start it it rev's up to a little over 2k and then drops back down. if you give it gas when its at 2k it bogs down and shuts off. it ran fine when i got to work i shut it off then cam back out and it wouldn't start.
dirty plugs, bad gas, bad tune. Did you check the oil to make sure that it wasn't milky could be head gasket. Who know is show a check engine code by chance if so scan it and find out.
i held the injectors out of the car and cranked the car and there spiting fuel out.
and the exhaust smells like gas...... bad tune yes its been running really rich but would it do this out of the blue?
You need to check your fuel pressure. simply seeing if its spraying isnt enough. make sure your air filter isnt cloggedcheck for faulty TPS, MAF. check for codes look at he condition of your spark plugs
Getaway_Driver
09-08-2015 09:41 AM
Adam144
09-03-2015 07:48 PM
