car wont start
car wont start
Just got my car back together got it running and was driving around. Someone bought the car and took it. On his way home it started acting funny and came up with a p1133 at first. He then tried to clear the code by unplugging the battery. Got it cleared and tried to start it and nothing. Then came up with a p0096 and p0116 and p0111. Cleared those and then the security light came on. Got the relearn done and still no start it cranks but won't kick over
i cant remember the code i threw, but when i swapped my stock injectors for 60lb during my whole stage 2 process, i couldnt get my car to start after. it would crank but wouldnt start. on the fuel rail there is a pieace that is pressed on i belive. any way when i went to tighten the fuel rail back up i ended up moving that pressed pieace. wich then didnt get pressure or air was leaking to it (idk exactly) but narrowed it down to that, and ended up JB welding that pressed pieace, letting it cure and then it started right up. few days later got a used fule rail swapped it and it started up. i know your de-modding your car so i thought this might help
I had the fuel rail out and cranked it to make fuel was coming of each injector and I do. It was running for most the day when I drove it. I then sold it and a half hour later this **** started to happen. Possible pcm?
Getaway_Driver
40
09-10-2015 09:11 AM
Getaway_Driver
09-08-2015 09:41 AM
Getaway_Driver
25
09-05-2015 09:16 PM
