CD stuck in headunit
Well I now have a CD stuck in the stock 05 headunit. Any body know how to fix it, or am I doomed to listen to the same CD from now on?
Tap as in smack the HU?
i had this problem, hit eject and have another cd ready when it ejects put the other cd in like a few inched and make contact lightly on the underside of the cd stuck in the player and just pull your cd in your hand out it should be enough to get the cd, its what i did for about a year till i just finally said **** it casue gm had gave me a new radio under warrenty and the same thing was happening, so i bought aftermarket
if you dont get the disk out press eject again and use your cd in hand to lightly press the other cd back in then it will go out of check disk, and you can try again, it might take you a fet trys but it is the simplest and cheapest way seeing as you wont have to pay anything to get it out.
i know the way im telling you may sound stupid, it does but it works and i could get mine out everytime it did it, it sucks that i had to go that route at the time but it does work and you wont break anything
Last edited by OneCOLDBIZL272; 06-11-2009 at 05:30 PM. Reason: Automerged Doublepost
