CEL light. running lean. what to do.
i installed gm 42# injectors. along with zzp 3" pulley and hub. now i have a CEL light on and had an appointment at gm today for a antenna bracket that was broke. the foound out about the stuff i did to it and said w/e they usually do. but neway. they said that the light is on because the injectors are not getting enough fuel or that is at least what the pcm is thinking. but i got the pcm from zzp and had it tuned to the 42 pound injectors. so basically im running realy lean and its trying to give it more fuel. so do you guys have anythning i can do to correct this and get rid of the light? THanks
