center console help
center console help
How does it come apart? I want to install shifter bushings but need to take it apart first to get to them. Any help is appreciated
i would recommend taking the entire center consol apart when installin the upgraded aluminum base bushings. i attempted to install the base bushings with the main huge center console still installed (main piece everything clips onto) and ended up droping a base bushing under the carpet. had to remove the main center part to retrieve it lol. but its alot easier and you have more room to work with. i believe the main center part has about 11 small bolts holding it down. the old bushings are pretty simple to remove. use a screw driver to pry out the metal washer/sleeve from the top then just push out the rubber bushing. replace with the upgraded and put everything back together.
I did what sterner said and removed the whole center piece. Deffinitely helped with my gorilla size hands.
Wasn't hard just felt like the screws were. 9 miles long
