Changed the headlights... its not locking in
One of my headlights went out... I thought it would be an easy fix, go to the auto store pick up a new bulb, pop it in... move on with life.
Found the following youtube video which helped me remove the headlight:
http://www.youtube.com/watch?v=y1wJUeuwaUg
but it doesn't show how to replace the bulb (which should be even easier, right?)... It was easy to remove the bulb, but putting it back on is another story... I gave up after about an hour of trying to lock it back in place... I couldn't get the bulb to fit like it was when I removed it. There's that black circle thing you have to turn counter clock wise to take off the socket with the bulb... so my problem is putting that back... I can't get it to lock back into place. i put the headlight back in cause I need to drive my car around, but I obviously can't leave it all lose like that. Has anyone had this problem?
Thanks.
Thanks.
yep... I even took out the new bulb and tried to place the old one back in the slot by itself, it didn't fit perfect. The red band that's around the bulb thing isn't going into place. maybe I'm too weak.
Keep turning the bulb until it is seated properly,you maybe a half a turn off,It really isnt that hard you are just missing something .
Keep trying you will get it.
there are 3 notches in the inside part of the bulb those match up with where the bulb sits in the housing. it will slide right in with minimal effort. then you put the black retainer on and plug her back in. very simple.
agentirons
10-16-2015 02:11 AM
importkiller
09-30-2015 07:18 PM
