check engine light on from cai
check engine light (MIL) came on after installing my cai it breaks up sometimes at random rpms and i have to shift.. PLEASE HELP if anyone knows wat wrong got robbed from the dealership and its under warrenty
I doubt its an oiled filter issue seeing as most people here run K&N and injen CAI's without issue. I would look for a leak or loose clamp . Is it possible that the maf is installed upside down or not tight? I ran a K&N drop in / airbox mod for over a year without issue , it would have to be way over oiled to cause a problem. How much vacuum are you pulling on the gage at idle?
