Clicking Noise every time I shift? WTF
I'm getting a Clicking Noise when I shift from 1st to 2nd most notably and it's really noticable while under very light accel. I did use the search and found out it may be my axles but everyone that seemed to have that issue heard the clicking under heavy load while I hear it under light load mostly? Anyone have any ideas? Thanks!
Could it be a bad TOB? As I believe I got one of the faulty GM TOB's when I put my New clutch in, Whenever I let off the clutch in neutral I can hear the bearings clicking/chattering and then goes away once I push the clutch back in.
Edit* I have had the GMPP before and yes they are awesome but my SPEC holds rediculous and also has stock engagement.
Figured out what the issue was, My right front Half Shaft is totally shot there's so much play that every time I shift or turn the wheel it makes a loud clicking noise, I'm lucky it didnt just fall the F off lol. My left side has some play in it as well, Apparently these are covered by GM's powertrain warranty and is going into the shop on Tuesday, Just a FYI.
wish i could tell ya. i was hearing a clicking noise pretty often at low speeds as well, figured it was my passenger axle so i replaced it... well the click is still there
next time i do my clutch i'm doing it with trained cobalt people because i feel like the shop that put my clutch and everything in didn't do it right. mad tob noise and all that
i still have some warranty left, so i might as well use it......
I'll most likely go talk to them tomorrow after i check my axels out....
wish i knew what he ment by they had "play" in them...
yeah i got you, i'll figure it out when i got the car in the air tomorrow, although OP i would like to know how you check for play in the Axel... pictures possibly if i can get some...
Although side note i did notice my left front hub bearing sounding like it was going out
*Edit: My left half shaft is toast as well, Soooo back in the shop she goes lol. Lots of tourqe will make them have a much shorter life span(at least thats what I hear)
brickloaf
09-25-2015 09:10 PM
breds2k
19
09-21-2015 10:24 AM
The Rookie24
09-20-2015 04:33 PM
