Clutch
A clutch works somewhat like a disc brake - either the friction material is burned off to the point where it doesn't grab, or (most likely) the springs and/or throwout bearing are worn out and it doesn't have the clamping force that it used to.
The clutch can slip with less than 400+ hp. Is it logical to state this as a blanket statement? I agree, though, that the clutch is slipping.
