Clutch engagement issues...
First off here is some info on what I have, KY clutch, stock flywheel, lsj slave, and a zzp clutch rod. When I first start to drive my car goes in gear fine, with no drag switching gears.. The more I drive the harder it becomes to get it in gear.. I replaced the master cylinder and the problem has remained.. I have no leaks and always seem to have good peddle. Any ideas?
