Clutch problems
Old 12-02-2015 | 12:01 PM
Chevy_life2146's Avatar
Clutch problems
Hi im.having some issues with my car I have a.2006 chevy cobalt ss 2.4 and I had put in a stage 2 proformance excdy clutch in it and my clutch had got stuck in so I took out the old master clutch cylinder and put in a new one and as I was installing it the pressure of the clutch had broke it what can I do is there a aftermarket master clutch cylinder?
Old 12-02-2015 | 12:33 PM
exninja's Avatar
If your question is "has someone made a stronger master clutch cylinder" then my answer would be that I doubt it. Did you get a new one and break that one too?
Old 12-02-2015 | 02:53 PM
Yeah I just installed it and and as I was stepping on the clutch so it could get pressure in it the master clutch cylinder pop out and it broke in half I have a stage 2 excdy clutch in it they said the pressure of the clutch is to much for the master clutch cylinder
Old 12-03-2015 | 08:11 AM
southal cobalt's Avatar
Its probably not the master cylinder itself. I had a similar issue with my act clutch. the steel plate that holds the master cylinder in place was broken. It has 2 tabs that are only about 1/16" thick and they tend to bend and break when you put a heavier clutch in. Id check those tabs and see how they look. That is if your master cylinder doesnt look broken
Are you turning it a 3/4 turn when instqlling it?
Old 12-04-2015 | 04:59 PM
I'll check it out and yeah my master clutch cylinder broke in half I just got a replacement on today
Old 12-04-2015 | 05:10 PM
Yeah I think the plate is broken just looked at it so I'm guessing I would need a new one
Old 12-05-2015 | 10:29 AM
The plate is available at crate engine depot if you plan to do it yourself. You have to pull out the entire dash to access it though. Theres a thread somewhere on here of a quick fix, but i dont remember what it was. If i had this issue again, i would probably rig something up to work,
Old 12-05-2015 | 11:31 AM
How much did it cost you to get it and I'm gonna have to get someone to install it did you install it your self
Old 12-05-2015 | 11:35 AM
And also how would I look up the part
Old 12-09-2015 | 12:02 AM
firehawk618's Avatar
Goto crate engine depot website, look for cobalt trans stuff.
It's there.
How in the world did you go from clutch master cylinder broke in half to needing a new firewall plate?
For the record the clutch master cylinder that oreilly's sells is STEEL. Yes you read right, it's made from metal.
EDIT: *The one for the LNF is metal and I presume that all Cobalts take the same one.
dbcartwright07
12-14-2015 03:08 PM
DirtyRyda
11-25-2015 06:44 PM
Izzy Ashley Barnett
11-19-2015 08:02 PM
bmartz1991
11-19-2015 11:48 AM
jarvislee024
11-14-2015 08:41 PM
Quick Reply: Clutch problems
